Response to switch problems
  • Hi guys
    Anyone experienced their dimmer 2 not responding well to their dimmer switch ? Two problems:
    - Toggling the dimmer switch - no light comes on, if i look at the app, the switch is on but the brightness is 1%. Seems to happen often across the house, the default brightness gets saved at 1%
    - One of my dimmers will only increase the brightness of my lights from the dimmer switch, the light gets stuck in full brightness and i can only turn the light off and on from then. I can reduce brightness from the app fine.
  • I seem to have the same issue with the switch not working. Not much to add, I'm still looking for a way to solve this. Might try rolling back to a 1.7 firmware and see if that helps (didn't have any issues before upgrading to 1.8...)
  • SparkyMaster 1. Oktober 2020 um 11:33
    Hat das Label Shelly Dimmer 2 hinzugefügt.
  • one of my dimmer issues was my mistake, i misunderstood what "single switch mode" and "dual switch mode" meant. I was using dual switch incorrectly, hence one of my dimmer switches was increasing brightness and the other dimmer was reducing brightness.
    I still have the issue though where sometimes when you try and turn a dimmer on, it comes on with 1 / 100 brightness which often means the light appears to be off. I need to then hold down the dimmer switch to wake the light up or increase the brightness.
