Shelly Dimmer 2 Offline
  • Hi All,
    I have 10 * Dimmer 2 at a customers installation. One continually went offline. Factory reset and set it back up it worked for one day then went offline again. I replaced with a new unit, worked fine for four weeks then started going offline also. Factory reset, set it back up, worked fine for two days and is now back offline. I now have two dimmer 2 that have the same problem. The other 9 have been working perfect till now. Any ideas? Thanks
  • Hello! Thanks ?
    All 10 dimmer 2 are located in an electrical panel which also contains an access point. All have fixed IP addresses. The other 9 operate perfectly. Just the one dimmer keeps loosing connectivity.
