Error 1
  • Hi,
    I had my dimmer2 connected with neutral because wifi was not stable without it.
    WIth the latest improvements in firmware I thought I'd try without neutral again (no neutral available where I want to use it). Wifi is stable now but after a few minutes the divice swithes off with Error 1.
    My guess is this is overtemperature since in the states json I see the temp running up over 100C.
    It did not do this with neutral connected. Any ideas?
  • Followup: It does the same now with neutral connected. Wonder if it has something to do with high voltage on the grid here. Can go up to 253 volt during a sunny day.
  • Hi and welcome to the forum. :)
    I think, this is to much.
    After some more experimenting I don't think voltage is the problem.
    It does go into overtemperature is mains voltage is over 250 Volts but the error1 happens with lower mains voltage too. And in that case temperature is not to high.
    See below screenshot after the error happens.
    It tried to change leading edge to trailing edge but the device seemed to crahs when I did that. Had to take is from power to get it running againa. No even the reset switch on thae back recovered it.
