Report URL
  • Hi all,
    I'm new to Shelly and to the forum. My question is what parameter value I have to put in the Action URL to get the different values for temperature Humidity and Battery?
    Today I have a URL looking like this: https://www.mydomain.com/sensordata/get…=1&temperature=tmp.value&humidity=hum.value&battery=bat.value
    Is it something I have missunderstood or doing wrong?
    Yes, the server address is a https, is that a problem?
    Is there any start/end tags I should use for the parameter values?
    I appreciate any thoughts and idéas! that can help me forward
    Kind regards
    Bjorn
    Einmal editiert, zuletzt von LordMav (15. September 2020 um 13:12)
    Hi and welcome to the forum, Bjorn, :)
    Shelly can only http.
    But perhaps, you can ask the shelly from your server side:
    http://ip.of.your.shelly/status
    Edit:
    Sorry, I just see just right now, you're talking about H&T, there it's not possible in this way because the sleep mode.;(
  • Hi Stefan!
    Allright,
    Moved the scripts and other to a non https address and some data are now coming thru.
    I now got humidity, but no temperature or battery values.
    Is the short-codes: tmp.value and bat.value correct or is there other shortcodes to use?
    Thanks for your effort and help!
    Kind regards,
    Bjorn
  • Hi,
    following actions URL feature...
    I was able to add listener for Shelly H&T "action" url - is there any more specific documentation on what values can be posted?
    by simply entering my IP/port of the listener in the actions URL I was able to get this details:
    GET //???/??hum=47&temp=24.38 HTTP/1.1
    Host: xxx.xxx.x.xxx:16900
    Content-Length: 0
    User-Agent: Shelly/20200812-091311/v1.8.0@xxxxxx (SHHT-1)
    This can be easily parsed with regex.
    Any chance to get battery level this way?
    This would make full logic of my Shelly H&T integration as push notifier instead of pinging it for status with GET it might update "on change" when it wakes up...
  • Ok,
    So without the extra coding for pinging back to the Shelly (not available to me)
    the only data I can get is the temperature and humidity.
    Here is the URL I have put together and set in my action URL field in my Shelly H&T
    device to get the info back to my server:
    http://URL_TO_PHP_SCRIPT_FILE.php?sensorid=XX
    The Shelly H&T device then adds (without me putting any more info to the string):
    &hum=40&temp=20.10
    Important (as said by Stefan above) the Shelly device cannot connect to a "https://" address.
    I would love to have the battery level also automatically added ie. bat=97
    Where in this example 97 is the percentage of the remaining battery level.
    THEN this little amazing thing would really rock the boat! ?
    Maybe something that could be implemented in a future firmware?
    Björn
