Shelly 2.5 PM - 3 way switch
  • Is there a way with the Shelly 2.5 PM to set it up that both switch inputs control output 1?
    I'm trying to wire up the Shelly 2.5 PM using my 3 way switch for a staircase but I don't have line voltage at the top of the stairs (the the light gets its power from) I used one of the switched wires to pass line from the bottom of the stairs and the second I wired up as constant line voltage to pass to the top of the stairs. I then hooked up each of the switched to their own input on the Shelly 2.5 and the light I hooked to output one. Unfortunately I can't find a setting in the Shelly 2.5 that will allow me to control one output with both SW inputs. Is there a setting that I have missed?
    Is this something that can be added to the firmware?
    hi @ryanbooker1 , welcome to the forum. :)
    A shelly "2.5 PM" don't exist. Du sprichst vom Shelly 2.5. ;)
    The feature exists already,
    To switch an own channel, do not use the IP in the request, use "localhost" in
    ACTION BUTTON SWITCHED ON URL.
