Dimmer doesn't switch off light completely
  • hello,
    I have just received a few shelly 2 dimmers, and installed one of them with philips dimmable LED lights (4x3.8w), neutral is not connected.
    When shelly is turned off, the bulbs still slightly glow (and flicker) that is noticeable at night. Also, when i open the shelly app, the lights start flickering (around 10% brightness) for a few seconds. Is there a way to fix this?
    I calibrated the dimmer a few times, that did not resolve the issue. Also, using the latest firmware, v1.8.4.
    2 Mal editiert, zuletzt von Icy#Darkness#14022 (9. September 2020 um 00:22)
  • Hi!
    I'm not an expert on this and I haven't had that issue yet but I'ld try adding LED lights with more wattage or the bypass for a try. The manual says 10 W should be enough, but 15.2 W is not that far away. I switched to shelly dimmer parallel to upgrading with old bulbs to LEDs and specially choose the high power leds so I don't come close to the 10 W.
