Two wires in 1 clamp
  • I would really advise you to use clamps if you want to connect more than one wire to a port of your Shelly (which clamp depends on whether you use solid wire or standard wire).
    The ports in the Shelly are soldered to the circuit board. By connecting more wires to one single port, you put unnecessary strain on the port (and the circuit board).
    I use as much standard wire as possible to connect my Shelly (I always tin the ends BTW) and connect them with clamps if I need two on one port.
  • SparkyMaster 17. September 2020 um 11:34
    Hat das Label Shelly EM hinzugefügt.
  • After 10 days, using 1 clamp 1 fase(wires) + 1 clamp 2 fases(wires), it works good.
    Explain:
    Delfuego-NL :1 clamp a 2 wires passing inside de clamp
    thanks
