unstable push button input when using AC optocoupler addon
  • Hi!
    I am noticing a flapping input during push-button long-press when using the AC optocoupler addon in this configuration:283-4xwhite-led-strip-shelly-pngThe problem goes away if I use the same push-button in a DC configuration without the AC optocoupler.
    This seems to be a common problem..
    I can work around the the issue in software by configuring a debounce filter with approximately 80ms delay (delayed_off: 80ms when using the esphome firmware).
    At a first glance I suspected it to be related to a single diode that rectifies only the positive half-waves of the AC-input. But in this case I'd expect a debouncing filter of approximately 20 ms should be enough.
    Any hints about the real reason of this effect?
    Is there a simple and clean workaround?
    (E.g. by adding a small capacitor (dimensioning suggestions?) after the AC isolator?)
    Cheers,
    --leo
    P.S.: Unfortunately I don't have neither an oscilloscope nor some caps here for further testing.
