Hi
Can anyone explain me what's that? As i can see sometimes apears a blue bar on button but i can't understaind nothing about that.
Hi
If the blue bar is on, the switch should be showed as on.
In case, you don't have a switch, this could be based on induction.![]()
So it means the phisical switch it's with energy?
yes
OK. Just a new question when the physical switch it's pressed on a 2.5 Shelly how the relay changes to on? The coil needs a DC current to close the coil? The processs it's equal to wi-fi command and sw command?[bugtracker][/bugtracker]
