Shelly 2.5 crashes/reboots after just opening Android app
  • Hi,
    I just received a parcel with two brand new Shelly 2.5 from Bulgaria and discovered a serious malfunction when setting them up.
    Unpacked, connected to 24V DC (+24V to N, GND to L, stable power supply, nothing else connected), connected to my wifi via browser, and upgraded to the latest firmware.
    When I switch on both relay channels via webbrowser the device crashes as soon as I open the android shelly app (latest version) afterwards.
    Crashing meens both relay channels are switched off, the red LED turns black, and the device starts booting again.
    This happens about 2-3s after I open the app, and happened even before I had the device added.
    If I switch on just one of the relay channels, everything works fine.
    I took the second brandnew device, connected it to 24VDC power, and can reproduce exactly the same behaviour.
    Need help, as this completely makes it unusable for my application. Any suggestions?
    wifi_staconnectedtruessid"XXXXXXX"ip"192.168.3.130"rssi-58cloudenabledtrueconnectedtruemqttconnectedfalsetime"17:09"unixtime1597511396serial4has_updatefalsemac"D8BFC01A6A29"cfg_changed_cnt0actions_statsskipped0relays0isontruehas_timerfalsetimer_started0timer_duration0timer_remaining0overpowerfalseovertemperaturefalseis_validfalsesource"http"1isontruehas_timerfalsetimer_started0timer_duration0timer_remaining0overpowerfalseovertemperaturefalseis_validfalsesource"http"meters0power0overpower0is_validfalsetimestamp1597511396counters001020total01power0overpower0is_validfalsetimestamp1597511396counters001020total0inputs0input0event""event_cnt01input0event""event_cnt0temperature62.28overtemperaturefalsetmptC62.28tF144.1is_validtrueupdatestatus"unknown"has_updatefalsenew_version""old_version"20200812-091015/v1.8.0@8acf41b0"ram_total49504ram_free36220fs_size233681fs_free147588uptime23
  • Not happening on 230V AC.
    I have a stabilized, 24V/12W/500mA DC voltage source. Should be well enough for a <1W shelly.
    Stable voltage on the oscilloscope, no dips or similar visible when relays are switched or the shellys crash.
    Can anybody reproduce?
