I have an error for dimmer 2.. see screenshot.
Connection L N only SW1 with 2 led lights...
After few second shelly turn off the light.
Do you know a solution?
Thanks
Mut
Thanks
Mut
Hi
@muttleyluke , welcome to the forum. ![]()
L on SW1 is the same L on L?![]()
Thanks..
Sorry for mistake...
O / N / L / SW1 correctly connected.... NO connection on SW2.
Lights works fine.. but after few seconds/ minutes alarm appears and turn off the light...
Thanks for help
Please check the temperature without load per http-request:
ip of dimmer/status
Maybe, the shelly is defect.
I change dimmer2 with shelly 1...
All is perfect..
I'll try as soon as possible with other connection..
Let me know if you find a solution...
Thanks
