Use Shelly 1 without any external switch
  • Hello,
    today I received my Shelly 1.
    What I wanted to achieve is basically to use it to turn on / off lights via Alexa.
    My setup looks like this:
    - brown wire - input Phase > connected to "L”
    - blue wire - input N > connected to "N"
    - brown wire > going to 5 LED array
    - blue wire > going to 5 LED array
    What I tried was to "simply" not attach anything to the "SW" port as I don't have or need an external switch.
    I was somehow hoping, that I could turn the switch on / off via the Shelly app and ultimatively with Alexa in the end.
    I could use the shelly app, add the Shelly 1 as new device, and now I am also able to use the app and tap that virtual "ON" "OFF" switch.
    When I do that I clearly hear the relay's click. But the lights are not switching on.
    When I checked the output ports with the phasing tester, I could see that there was output at all when switching.
    Am I missing something?
    Is this device also meant to work for my scenario or do I need a switch to get this to work?
    Thanks a lot
  • First of all thanks for your quick response!
    No, my LEDs are permanently off right now.
    They don't turn on.
    If I ignore the right part of you image (switch and transmitter), I realize that I clearly did NOT wire my lights like the receiver / socket setup.
    This is what I did instead:
    Obviously my wiring does not work, so I'll try your suggestion tomorrow.
    Thank you VERY much!
