Recommended LED driver, compatible with Shelly Dimmer?
  • I have a single switch to turn on my LED strip and want to have Shelly Dimmer installed. As far as I understand, I need dimmable LED driver, but there are several methods of dimming and I'm not sure which of those Shelly Dimmer supports. Can anyone recommend me LED drivers for 24V 100W LED strip? Maybe something from MeanWell series?
    Also, wiring scheme with supported LED driver would help A LOT, since I can't figure it out by using the one in the manual. Thank you in advance!
    Hi @maskatuoklis , welcome to the forum. :)
    The RGBW2 could be the better choise. Wiring schemes are in our lexicon. ;)
  • Hi @maskatuoklis , welcome to the forum. :)
    Sadly I've bought several Shelly Dimmers and wanted to make them work :( Is there anything I could to to make them work in my case?
    I will consider RGBW2 as a last resort.
    P.S. Thank you for welcoming ;)
    Einmal editiert, zuletzt von Blue#Hill#10686 (4. Juli 2020 um 15:07)
