Having trouble with timers?
Hinweis für Entwickler
  • Hello all -
    I'm having a hell of a time trying to get a Shelly script to work with Timers. I know what I'm after, but it does seem like the asynchronous execution of this JavaScript is biting me. It's a very simple script, but every time I add another timer it seems like the call stack just balloons into infinity and then I "run out of" timers. Basically, my script needs to:
    1. Turn the Shelly on.
    2. Wait two minutes.
    3. Use the HTTP.Get to check if a certain webpage is up, and print to the console the number of reboots, the number of successes (times it got the webpage) and the number of failures (times it failed to load the webpage).
    4. Turn the Shelly off.
    5. Repeat.
    In order to repeat this, I use a five second timer to repeat the process... but I'm obviously ALSO using a timer to delay firing off the HTTP.Get part of the script. How do I solve this? If this were a synchronous script, this would be cake, but... it isn't, and async code is something I'm MUCH less experienced with (and extremely frustrated by, but I'm here to learn!).
  • I'm not sure if I understand the desired functionality completely, but the following code should run without technical difficulties. This version will:
    1. Turn the switch on
    2. Wait 115 seconds
    3. Check if the endpoint can be reached
      • if no: increase the failCount, wait 5 seconds and go back to step 3
      • if yes: increase the rebootCount, turn the switch off and immediately restart from step 1
    Two notes:
    • You define a CONFIG.rebootToggleTime, but it is never used
    • The CONFIG.httpTimeout variable is not defined, so I added it with a value of 10
    Let me know if this does what you need...
  • //http timeout, magic number, not yet documented
    https://shelly-api-docs.shelly.cloud/gen2/Component…es/HTTP#httpget
    Your script is mysterious.
    Reboots? Of which device? Where does the information about the number of reboots come from?
    What is hidden behind the IP address of CONFIG.endpoint?
