I have a 2 Shelly relays installed and working, but only this one is having connectivity issues.
I have Cloud access disabled, and Eco Mode is enabled.
I've noticed that in the app, the device shows the incorrect IP address. Other than the one faulty device, the correct IP (as reported by my router) works to access the device webpage.
A month ago, I was able to connect via the app and disabled the active schedule. Not sure when after that the issue started.
I've tried to power cycle the faulty unit, connect via local IP, and connect via the Android app, no luck. It's odd that it still works via Home Assistant. Although that connection is via bluetooth.
What options do I have short of a device reset?
