control blinds with a virtual single click button (vie zwave)
  • Hello,
    I'm running out of physical buttons on my smart button. I want to control my blinds with a single click. The logic for a single click is as follows:
    • blinds not moving
      • last target fully open --> close blinds
      • last target fully closed --> open blinds
    • blinds moving --> stop moving
    According to wiring on Documentation about Wave Shutter - Shelly Europe it can be controlled by single button:
              All_Wirings_Qubino_800_V2_shutter_popravljeno-02.png?inst-v=9920217c-2390-4809-8655-f1dfdd45dabf    03_Wave%20Shutter-wiring_diagram.png?inst-v=9920217c-2390-4809-8655-f1dfdd45dabf
    That plus the description of
    Zitat
    Parameter No. 1 – Push-button (momentary) / bistable (toggle switch) selection
    With this parameter, you can select between the switch type: push-button (momentary) or on/off toggle switch connected to SW1 and SW2 inputs.
    Value size: 1 Byte
    Default value: 0
    Values & descriptions:
    • 0 - momentary switch
    • 1 - toggle switch (contact closed - ON / contact opened - OFF)
    • 2 - single, momentary switch (the switch should be connected to SW1 terminal)
    NOTE: When set = 2, 1x click on SW1 up - 1x click on SW1 stop - 1x click down
    makes me think it should be feasible.
    Is there anyone who has done this before and can share how?
    Thank you
    Stefan
