Feature Request: Disable Bluetooth advertising while keeping RPC and proxy enabled
  • Hi Shelly team,
    Many Home Assistant users (including myself with 20+ Gen3/Gen4 devices) use Shelly devices as Bluetooth proxies to extend BLE coverage for sensors and presence detection.
    The proxy works, but every device constantly advertises its name, cluttering Bluetooth scans on phones and other devices.
    Technically, the device's own advertising is not needed for proxy functionality — the device only needs to scan and forward advertisements to HA over Wi-Fi.
    Currently, advertising stops only when RPC is disabled (per BLE.SetConfig docs), which also breaks the proxy.
    Request: Add an option (web UI or API) to disable the device's own advertising while keeping Bluetooth enabled and RPC fully active — essentially a non-discoverable mode for proxy-only use.
    This would greatly improve the experience for users with multiple proxies.
    Thanks for considering!
    Best,
    Black
  • Did I understand this right:
    If I disable "Enable RPC" within the Bluetooth-Menue at the Shelly Proxy-Device the Proxy-Feature for Home Assistant does NOT work anymore?
    I use several Shelly Plus 2PM (= Gen2) with this option disabled, but the proxy for my home assistant is still working
    As I understood this the "proxy"-Feature is provided by the "aioshelly_ble_integration" script installed by home assistant if you activate active/passive BT scanner mode for the spezific shelly device
  • Ist doch einfach zu testen was Homeassistant benötigt 🤔
    Bluetooth im Shelly deaktivieren und in HA das Gateway (passiv) aktivieren
    Dann werden automatisch die Einstellungen im Shelly gesetzt und das Script wird übermittelt
  • Bluetooth im Shelly deaktivieren und in HA das Gateway (passiv) aktivieren
    I did not try it that way, I "disabled parameters until HA did not work anymore" and THAT configuration was my result (BT + Script activated, BT RPC deactivated)
