Hello,
Any idea how I can disable the LED on the gen 4 Power strip when using Zigbee? I didn't find anything in the documentation and I don't need the LEDs at all.
Thanks!
Hello,
Thanks!
The power strip is part of a zigbee network managed by Home Assistant. I don't know how I would access it from the shelly app without switching back to wifi mode.
Wifi and Zigbee can be used in parallel. So you could switch off the light via Wifi using the app and then switch off Wifi if you want (= Zigbee only).
Thanks for the idea!
Unfortunately my power strip cannot run wifi and zigbee in parallel. But I was able to turn on AP mode (by holding buttons 1 and 4 pressed for 5 seconds) and connect to the strip's web jnterface to disable the LEDs. Then turned zigbee back on which immediately disabled wifi. But the LEDs are off.
I guess I'll need to do this to update the firmware in the future.
