temperature offset tuning
  • my device is Shelly H&T Gen3 on firmware v1.7.1
    I'm desperately trying to offset the temperature by a custom margin - exactly -1.8°C
    why? i have another non-shelly thermostat that controls a pump1 based on the temperature in room. with shelly H&T gen3 I need to control pump2 also based on the temperature. for the best effect I need both pumps to be in sync and turn on/off together. the non-shelly thermostat can't be changed nor configured (there is no offset in it)
    I read somewhere in shelly forum that I can set custom value of humidity via url ignoring the gui threshold and AI failed to help me achieve it
    this is what I tried:
    http://192.168.1.128/temperature/0?offset=-1.8
    http://192.168.1.128/settings?temperature_offset=-1.8
    device is not pw protected, and ofc running in setup mode. I even tried:
    and also directly in console like:
    fetch("http://192.168.1.128/rpc", {
     method: "POST",
     headers: {"Content-Type":"application/json"},
     body: JSON.stringify({"id":1,"method":"Device.SetConfig","params":{"temperature_offset":-1.8}})
    }).then(r => r.text()).then(console.log)
    but nothing worked. please help me out with this. is there any way how to make it?
