I notice that my shelly em gen3 at the time that is distorted. In logs, it is based on the internal clock (RTC) but never via the ntp server. I tried everything, every time, I have the time that is not correct until I reach several hours sometimes. On the ntp server, I put https or http or removed it. I set time.cloudflare.com, I tried time.google.com . I changed the DNS (by putting 8.8.8.8 or 1.1.1.1 or even 192.168.1.1. I always have Setting time from RTC in the diagnostic mode with values several times negative. I end up with false scripts because the time is not respected sometimes several hours.
