Philips dimmable LED's strange behaviour
  • Hi all, I have multiple Shelly Dimmer 2 devices installed (more than 4 of them). All work as expected, except those in combination with a few Philips GU led spots.
    The exact spots used are: Philips Master Value GU10 led spot 3.7W (35W) DimTone 270lm and EAN 8719514312289
    One of the devices with strange behaviour has 6 led lights and the other dimmer has 8 led lights. All bulbs are exactly the same and I have them everywhere in my house. (Others are controlled by Z-wave Qubino's) On both of these two shelly Dimmer 2 devices some led lights are not turned on sometimes. Strange enough it often are the same led lights which are not turned on. Sometimes all lights work, sometimes there are 3 lights not working sometimes 2. It looks a little random.
    When I install a halogen spot-35W in a " not working" location it works.
    I am on the latest firmware and today I tried one off the devices with de beta firmware. It makes no difference.
    Anyone else with the same problem here? And how can I fix this?
    a lot of shelly's including:
    - Dimmer 2
    - i4
    - 2.5
    - pro 2pm
  • Servus, do I understand right: 6 or in the other case 8 LED lights are connected in a parallel to the Shelly Dimmer output, but some are not always working? Then it is rather a contact problem. If you have maybe used them before for Halogen lights, they might be aged due to the strong heat. You should exchange the GU10 sockets.
