Shelly App loses conection with Shelly device
  • Hello.
    I'm the almost-happy owner of a Shelly 2.5 used on a roller shutter. I purchased it to be used mainly trough MQTT tough I've been able yet to use it like that, but I'll!!! my intention is to install it on all my 7 windows.
    So meanwhile I learn how to do the MQTT thing... I use the app on my IphoneX. the problem is that I get a lot of "disconnected" messages when Im using it, the app loses connection with the device. Wifi signal is good, (no more than 5 meters from router) latest firmware, latest app... but no solution.
    I've tried with andorid and works like a charm. but not from IOS.
    any clue?
    thanks!
    edit, same issue from my ipad
    Einmal editiert, zuletzt von Green#Mountain#9414 (3. Juni 2020 um 22:15)
  • EDIT: Restored to factory default solved the issue
    I have pinpointed the issue. If I click on Enable MQTT on the shelly web interface, I lose the device on the Sehlly APP (but can still reach it on the web interface, so no conecction is really lost)
    Einmal editiert, zuletzt von Green#Mountain#9414 (20. August 2020 um 16:19)
  • I am facing the exact same problem. I am running my Shellys (21 2.5) with the latest FirmWare und als have the newest App installed. But I still lose connections every day.
    Issue: I open the Shelly App and using it. After a few seconds most of the devices are not reachable. Even if I opened the same roller shutter seconds ago - it´s gone. Same problem with relays.
    @ifr Are you using a MESH-WLAN?
    As you already mentioned before: the Shellys are not really offline or disconnected. No issues, if I try to connect via web interface.
    Einmal editiert, zuletzt von BlackHawk1942 (16. September 2020 um 14:11)
  • My rgbw2 connected initially, now nothing. I can’t even delete the device. So frustrating.
