Germany - device recommendation and how to wire
  • Hello, I would like to monitor electricity consumption of my electric stove, I have home assistant and shelly integration. I am interested which shelly device is recommended for this use case and how to wire with the cables in the wall (see the picture). Ideally device should have WiFi and consumption measuring, all other features are optional.
    Thank you!
  • The wall-adapter shown in the picture has 3 Live wires + N + PE as inputs, but only one L ( the brown one ) is conected to the cable.
    So I assume, your stove needs only one L + N + PE.
    Question: What is the maximum power rating ( Watt ) of your stove?
  • Kannst du ein Foto von dem Herd und dessen Typenschild senden? Wenn es ein Herd ist, sollte der mit 3 Phasen anzuklemmen sein.
    Die Herdanschlussdose sollte direkt auf Sicherungen der Unterverteilung gelegt sein, so dann kann vielleicht einen in der Unterverteilung installieren kann.
