Counting Pulses using a Shelly Plus Add-On and Shelly 1PM Gen3
Hinweis für Entwickler
  • Hi all,
    Me and my colleague want to connect a flow meter than outputs pulses to a Shelly Add-On's digital input. We want to install the Shelly Add-On on a Shelly 1PM Gen3 Device in order to control a relay based on pulse counts. I was wondering if this is possible, and if yes, how?
    I'm fairly comfortable with scripting. I'm assuming the digital input from the Add-On will show up as an "input" component on Shelly.GetConfig like so (below is only an example I made up):
    "input:2": {
        "id": 2,
        "name": "Flow",
        "type": "count",
        "enable": true,
        "counts": {
          "total": "43"
    Is this correct? I'm just not sure if the Shelly 1PM Gen3 Device can accept Digital Input signals from the Add-On and that maybe it's only meant for temperature/humidity Add-On sensors. Thanks!
