Wall Display: Temperature change does not (reliably) fire action
  • I installed an action (Only when the temperature changes) that hits an URL with the parameter $temperature.
    The event is triggered randomly but not at every temperature change (Temperature Delta Threshold is set to 0.5).
    The equivalent humidity action (parameter $humidity) fires reliably.
    My Wall Display works as a thermostat and uses an external BLU HT sensor.
    Any ideas?
