How to see the Current (in Ampere) log in 3EM or EM
  • Hi,
    I am using shelly products for last 5+ years and absolutely love it. I have 3EM installed and am able to check the power consumption and voltage logging. But I have a few questions:
    1. Can I have a current (Ampere) log? What is the min resolution? per minute?
    2. Can I have the maximum and minimum current over 24 hours/ 30 days? Same like voltage or power consumption...
    Thanks
  • Thanks for the reply. Quite unusual that ampere is not logged. At least does shelly give max and min ampere over a period of time?
    Also can you give more details on "Home assistance" device??
    Thanks
    -Gopal
  • Also can you give more details on "Home assistance" device??
    This is no device, it is a home automation software: https://www.home-assistant.io/
    You can also search here in the forum. A lot of users use this software. There are alternatives, sure, but HA (Home Assistant) is quite popular.
    I took another look: Unfortunately, there is not even a min/max for this.
    Mehrere PRO 3EM im Einsatz
  • Ok...so HA is just the software. So to measure current (in Ampere) can we use Shelly hardware or any other sensor is needed for min/max ampere measurement?
    I am sure I am not the only person looking for a solution for this. Do you have any pointer for sensor/software solution for this min/max ampere measurement? I mean from where to start exploring??
    -Gopal
