Shelly Gas LPG resolution
  • My Shelly Gas LPG has reported values of 0 ppm and occasionally 600 ppm. The threshold for a low alarm is 1800 ppm and 3000 ppm for high alarm. I suspect the device only measures in 600 ppm increments. If so, the low and high alarms would trigger at 3 and 5 increments, not much discrimination.
    Has anyone seen a ppm value that is not a multiple of 600?
  • Hello homeowner.
    I dont have a resolution, but I also share you questions. I am in the UK and my readings are either 0 or 600ppm. It must be the tolerances.
    Is 1800 a good point to set the alarm? Apologies, I am a noobie.
    Steve
