Scripting / Szenen und HTTPs Anfragen
  • Moinsen Leute,
    ich möchte gerne meine Shelly's und das ganze drum herum noch etwas smarter machen.
    Jetzt stellen sich mir ein paar Fragen und ein paar weitere Themen wo ich Hilfe bräuchte..
    Kann der Shelly Anfragen per HTTPS mit GET oder POST an meinen Webserver stellen?
    Dann möchte ich das ganze im Scripting einbauen hab folgenden Beispielcode aus der Bibliothek geladen:
    Spoiler anzeigen
    /******************* START CHANGE HERE *******************/
    let CONFIG = {
    // When set to true, debug messages will be logged to the console
    debug: false,
    // When set to true the scan will be active, otherwise it will be passive.
    // Active scan means the scanner will ping back the Bluetooth device to receive all its data, but it will drain the battery faster
    active: false,
    // When `allowedMacAddresses` is set to null, evets from every bluetooth device are accepted.
    // allowedMacAddresses: null,
    allowedMacAddresses: [
    "aa:bc:12:34:56:78", // events only from these mac addresses are allowed.
    "11:22:33:45:5a:bc",
    * Called when motion is reported from the filtered Shelly BLU Motion devices.
    * @param {Boolean} motion true, when there is a motion, false otherwise.
    * @param {Object} eventData Object, containing all parameters received from the Shelly BLU Motion device. Example: {"encryption":false,"BTHome_version":2,"pid":16,"battery":100,"illuminance":109,"motion":1,"button":1,"rssi":-53,"address":"aa:bc:12:34:56:78"}
    motionHandler: function (motion, eventData) {
    // Toggle the first replay ON/OFF based on the motion value.
    Shelly.call("Switch.Set", { id: 0, on: motion });
    console.log("Motion", motion);
    * Called when illuminance is reported from the filtered Shelly BLU Motion devices.
    * @param {Number} illuminance Current illuminance value.
    illuminanceHandler: function (illuminance, eventData) {
    // Compile the topic based on the mac address of the reporter.
    let topic = eventData.address + "/illuminance";
    // Publush the data.
    MQTT.publish(topic, String(illuminance));
    * Called when packet from filtered Shelly BLU Motion devices is received.
    onStatusUpdate: function (eventData) {
    // Do nothing at the moment.
    /******************* STOP CHANGE HERE *******************/
    const ALLTERCO_MFD_ID_STR = "0ba9";
    const BTHOME_SVC_ID_STR = "fcd2";
    const uint8 = 0;
    const int8 = 1;
    const uint16 = 2;
    const int16 = 3;
    const uint24 = 4;
    const int24 = 5;
    // The BTH object defines the structure of the BTHome data
    const BTH = {
    0x00: { n: "pid", t: uint8 },
    0x01: { n: "battery", t: uint8, u: "%" },
    0x02: { n: "temperature", t: int16, f: 0.01, u: "tC" },
    0x03: { n: "humidity", t: uint16, f: 0.01, u: "%" },
    0x05: { n: "illuminance", t: uint24, f: 0.01 },
    0x21: { n: "motion", t: uint8 },
    0x2d: { n: "window", t: uint8 },
    0x2e: { n: "humidity", t: uint8, u: "%" },
    0x3a: { n: "button", t: uint8 },
    0x3f: { n: "rotation", t: int16, f: 0.1 },
    0x45: { n: "temperature", t: int16, f: 0.1, u: "tC" },
    function getByteSize(type) {
    if (type === uint8 || type === int8) return 1;
    if (type === uint16 || type === int16) return 2;
    if (type === uint24 || type === int24) return 3;
    //impossible as advertisements are much smaller;
    return 255;
    // functions for decoding and unpacking the service data from Shelly BLU devices
    const BTHomeDecoder = {
    utoi: function (num, bitsz) {
    const mask = 1 << (bitsz - 1);
    return num & mask ? num - (1 << bitsz) : num;
    getUInt8: function (buffer) {
    return buffer.at(0);
    getInt8: function (buffer) {
    return this.utoi(this.getUInt8(buffer), 8);
    getUInt16LE: function (buffer) {
    return 0xffff & ((buffer.at(1) << 8) | buffer.at(0));
    getInt16LE: function (buffer) {
    return this.utoi(this.getUInt16LE(buffer), 16);
    getUInt24LE: function (buffer) {
    return (
    0x00ffffff & ((buffer.at(2) << 16) | (buffer.at(1) << 8) | buffer.at(0))
    getInt24LE: function (buffer) {
    return this.utoi(this.getUInt24LE(buffer), 24);
    getBufValue: function (type, buffer) {
    if (buffer.length < getByteSize(type)) return null;
    let res = null;
    if (type === uint8) res = this.getUInt8(buffer);
    if (type === int8) res = this.getInt8(buffer);
    if (type === uint16) res = this.getUInt16LE(buffer);
    if (type === int16) res = this.getInt16LE(buffer);
    if (type === uint24) res = this.getUInt24LE(buffer);
    if (type === int24) res = this.getInt24LE(buffer);
    return res;
    // Unpacks the service data buffer from a Shelly BLU device
    unpack: function (buffer) {
    //beacons might not provide BTH service data
    if (typeof buffer !== "string" || buffer.length === 0) return null;
    let result = {};
    let _dib = buffer.at(0);
    result["encryption"] = _dib & 0x1 ? true : false;
    result["BTHome_version"] = _dib >> 5;
    if (result["BTHome_version"] !== 2) return null;
    //can not handle encrypted data
    if (result["encryption"]) return result;
    buffer = buffer.slice(1);
    let _bth;
    let _value;
    while (buffer.length > 0) {
    _bth = BTH[buffer.at(0)];
    if (typeof _bth === "undefined") {
    console.log("BTH: Unknown type");
    break;
    _value = this.getBufValue(_bth.t, buffer);
    if (_value === null) break;
    if (typeof _bth.f !== "undefined") _value = _value * _bth.f;
    if (typeof result[_bth.n] === "undefined") {
    result[_bth.n] = _value;
    else {
    if (Array.isArray(result[_bth.n])) {
    result[_bth.n].push(_value);
    else {
    result[_bth.n] = [
    result[_bth.n],
    _value
    buffer = buffer.slice(getByteSize(_bth.t));
    return result;
    function onReceivedPacket(data) {
    if (CONFIG._processedMacAddresses !== null) {
    if (CONFIG._processedMacAddresses.indexOf(data.address) < 0) {
    logger(["Received event from", data.address, "outside of the allowed addresses"], "Info");
    return;
    if (
    typeof CONFIG.motionHandler === "function" &&
    typeof data.motion !== "undefined"
    CONFIG.motionHandler(data.motion === 1, data);
    logger("Motion handler called", "Info");
    if (
    typeof CONFIG.illuminanceHandler === "function" &&
    typeof data.illuminance !== "undefined"
    CONFIG.illuminanceHandler(data.illuminance, data);
    logger("Illuminance handler called", "Info");
    if (typeof CONFIG.onStatusUpdate === "function") {
    CONFIG.onStatusUpdate(data);
    logger("New status update", "Info");
    //saving the id of the last packet, this is used to filter the duplicated packets
    let lastPacketId = 0x100;
    // Callback for the BLE scanner object
    function BLEScanCallback(event, result) {
    //exit if not a result of a scan
    if (event !== BLE.Scanner.SCAN_RESULT) {
    return;
    //exit if service_data member is missing
    if (
    typeof result.service_data === "undefined" ||
    typeof result.service_data[BTHOME_SVC_ID_STR] === "undefined"
    return;
    let unpackedData = BTHomeDecoder.unpack(
    //exit if unpacked data is null or the device is encrypted
    if (
    unpackedData === null ||
    typeof unpackedData === "undefined" ||
    unpackedData["encryption"]
    logger("Encrypted devices are not supported", "Error");
    return;
    //exit if the event is duplicated
    if (lastPacketId === unpackedData.pid) {
    return;
    lastPacketId = unpackedData.pid;
    unpackedData.rssi = result.rssi;
    unpackedData.address = result.addr;
    onReceivedPacket(unpackedData);
    // Initializes the script and performs the necessary checks and configurations
    function init() {
    //exit if can't find the config
    if (typeof CONFIG === "undefined") {
    console.log("Error: Undefined config");
    return;
    //get the config of ble component
    let BLEConfig = Shelly.getComponentConfig("ble");
    //exit if the BLE isn't enabled
    if (!BLEConfig.enable) {
    console.log(
    "Error: The Bluetooth is not enabled, please enable it from settings"
    return;
    //check if the scanner is already running
    if (BLE.Scanner.isRunning()) {
    console.log("Info: The BLE gateway is running, the BLE scan configuration is managed by the device");
    else {
    //start the scanner
    let bleScanner = BLE.Scanner.Start({
    duration_ms: BLE.Scanner.INFINITE_SCAN,
    active: CONFIG.active
    if (!bleScanner) {
    console.log("Error: Can not start new scanner");
    if (
    typeof CONFIG.allowedMacAddresses !== "undefined"
    if (CONFIG.allowedMacAddresses !== null) {
    // Process configured mac addresses all to lower case and remove duplicates.
    CONFIG._processedMacAddresses =
    CONFIG
    .map(function (mac) { return mac.toLowerCase(); })
    .filter(function (value, index, array) { return array.indexOf(value) === index; })
    else {
    CONFIG._processedMacAddresses = null;
    //subscribe a callback to BLE scanner
    BLE.Scanner.Subscribe(BLEScanCallback);
    In das Script würde ich gerne einbauen, dass ich die Daten die ausgewertet werden auch an meinen Server senden kann und dass Shelly XY geschaltet wird.
    Das ganze dann am besten noch mit wenn dann also quasi wenn hell dann kein Licht wenn dunkel dann ja.
    Außerdem hab ich das Problem, dass zumindest per Szene das Licht bzw. die Bewegung von BLU Motion nur alle paar Minuten sporadisch erkannt wird und nicht im Sekunden Bereich.
    Kann mir da jemand sagen, wie das ganze eingestellt werden muss?
    Muss ich den Beacon Modus anschalten um häufiger Updates zu bekommen damit ich den Bewegungsmelder quasi normal benutzen kann?
    Alles weitere kommt dann noch im weiteren "Gesprächsverlauf "
    Falls weitere Infos benötigt werden, gerne Anfragen.
    Bin noch ziemlich neu in den ganzen und möchte gerne so einiges umsetzen bin aber manchmal noch etwas überfragt.
    Vor allem halt mit dem sporadischen Motion Updates.
  • Kann der Shelly Anfragen per HTTPS mit GET oder POST an meinen Webserver stellen?
    Ja, das geht mit Shelly Script:
    https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/HTTP/
    Nur per GET auch direkt in Aktions / Webhooks:
    https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Webhook
    Dieses Script wertet die BLU Daten "zu Fuß" aus. Das ist seit längerem nicht mehr notwendig, weil man die BLU Geräte bequem per BTHome einbinden kann. Die BTHome Daten kann man recht einfach per Event- bzw. Statushandler in Skripten abfragen.
    https://shelly-api-docs.shelly.cloud/gen2/Scripts/S…ddstatushandler
    https://shelly-api-docs.shelly.cloud/gen2/General/Notifications
    Mehrere PRO 3EM im Einsatz
  • Kleiner Hinweis: Bitte zur besseren Lesbarkeit Skripte in einen Code-Block einfügen:
    Sonst macht die Forensoftware lustige Dinge aus deinem Code.
  • Wow nice danke für die schnelle informative Antwort ;)
    Das ist auf jeden Fall schon Mal praktisch, dass das geht. Dann kann ich mein SMS Gateway gleich mit einbauen ich wollte nämlich gerne ne Alarmanlage auch in Zukunft noch zusammenschustern.
    Mein Gedanke war nämlich alle Fenster und Türen sowie Bewegungsmelder zusammen zu packen und auszuwerten. Dann wenn irgendwas noch offen ist, eine Rückmeldung beim scharf schalten geben, welche man auch noch quasi dann bestätigen muss, wenn man es ignorieren nochte und wenn dann irgendwas auslöst bzw. geöffnet wird oder sich bewegt, soll man mit einem Piepser noch darauf kurz aufmerksam gemacht werden, dass man beim vergessen des unscharf schaltens noch Zeit hat und ansonsten sollten dann 2 Sirenen außen und oder innen an gehen bis man das ganze wieder bestätigt.
    Hab noch n alten Pi 2B und 3B . Die sind zwar überdimensioniert aber dann brauch ich nicht zwangsläufig was neues.
    Daran ein Tastenfeld und evtl. n kleinen Bildschirm und damit dann den Alarm schalten.
    Ich hoffe das ganze geht so "einfach" wie ich mir das vorstelle.
    Oh lol ja ok eigentlich hatte ich in dem Spoiler einen Code Block eingefügt, kann sein das der bei Copy Paste am Handy irgendwie verloren gegangen ist. Das hatte ich letztes Mal schon, da hab ich auch Code Block gemacht und es wurde so eingefügt.
    Sorry dafür.
    Und danke für die Info.
