Shelly 3EM Get Status with truncated results
  • Hi I need one help
    I am running my Script in a Shelly Plus 1PM to control and monitor one Shelly 3EM, the project is a CEE 16A plug that I have in my garden so I only want to have power in it if I am charging my car if not will be Off.
    I have already created a BLE Scan script that turns ON the relay in the Shelly EM3 once car approach.
    Now I would like to implement a script where after detecting Relay ON and No Power consumption after 5 min it will turn OFF relay.
    I have tried may ways but no success,
    looks like in order to get my Shelly EM3 status I need to get it via http, fine but parsing it is a problem looks like the json is truncated
    DEBUG I have added in my Code
    URL with Status
    Any Idea why its getting truncated ? Any recomended solution ?
    I have version 1.11.7
  • There is a length restriction for the output lines. The lines are then wrapped accordingly.
    In addition: The console output only has a limited buffer to print things. Therefore, they are sometimes cut off.
    Have a look here for a workaround:
    gantim
    20. Januar 2025 um 18:22
