Bluetooth Detection to activate front house Lights
Hinweis für Entwickler
  • Have a look here as a starting point
    tvbshelly
    7. Mai 2025 um 20:39
    Mehrere PRO 3EM im Einsatz
  • I Have tried the following but the it is not scanning I have 1.7.2 in one shely plus and 1.6.2 in another and both are not scanning.
    Do you have any idea why scanning is not working ? I want to use it as it can detect my keychain so then I can play with what I want to activate post detection. But i can not scan and do not know why.
  • Have you read and understood the linked example?
    Pls. try this as a starting point to find the BLE mac of your Beacon device:
    function bleCallback(event, device) {
      if (event !== 2) {
        return;
      print (device.addr + " " + device.rssi + " " + device.local_name);
    BLE.Scanner.Start({duration_ms: BLE.Scanner.INFINITE_SCAN});
    BLE.Scanner.subscribe(bleCallback);
