Shelly Dimmer Gen3 with PIR
  • I’ve purchase Two ‘Dimmer Gen3’ modules to control lights on two different circuits so they come on together when triggered by PIR on either Dimmer ‘S1’ terminal.
    The PIRs in:
    OFF state are at ‘161.5V 0hz’
    ON state at ‘240V 50hz’
    Ideally I want to have the following setup:
    Light ON dimmed to 50% brightness 1hour after sunset until 11:30pm.
    After sunset and before sunrise if PIR ON (time delay on PIR) light goes to full brightness until PIR ‘OFF’ dims to 50% if before 11:30 OR OFF if between 11:30 and sunrise.
    There are PIRs on both Dimmers. When one operates it should tell the other to do the same.
    Is this possible? Just getting it to operate with the PIR would be a start!
    Thanks
    Dave
  • Did you make progress?
    I have set up my one PIR with lights and have the lights come on at 50% based on sunset time +/- and off at sunrise +/-.
    If PIR is active lights go to 100% and when PIR goes off I set lights back to a configured %.
    The only issue I have is the lights have to be told to go back to % setting I had them on at, I can't get them to actually remember that they were at 50% before.
