Can't get duration to work
  • Hi,
    I've been trying to download a schedule into the Plug S + V2. Can get most of the parts of the schedule to work, but can't get the duration function to load. I had Claude try everything that we could conceive and could never get a delay and state change.
    { "method": "Switch.Set", "params": { "id": 0, "on": True, "duration": 22000 # Milliseconds of mystical transformation }}
  • Do replace "duration" with "toggle_after"! The unit is second, not millisecond.
    https://shelly-api-docs.shelly.cloud/gen2/Component…witch#switchset
    Einmal editiert, zuletzt von eiche (24. Mai 2025 um 22:41)
  • Thank you -I'll try that. I found that all of the other time entries had to be in milliseconds though, in order to work. ---
    I tried it and it worked!!! Thanks so much! - Douglas
