H&T controlling 0-10V control on MVHR
  • I have an Airflow entro DV300 MVHR unit that has the ability to control the fan speed with a 0-10V input. Is this achievable using a shelly H&T to monitor the humidity of a room and adjust the speed of the MVHR accordingly. Many Thanks
  • I'd try a Shelly 0-10V dimmer including an add-on and DHT22. A H&T reacts relatively slowly to changes in measured values.
    to the device
    Perhaps this can be achieved in a user-friendly way with a H&T. You'll have to figure that out. I don't have a 0-10V dimmer. It can probably be configured appropriately. A script will certainly work.
