No connection with my BLU H&T
  • Hello every one,
    I have a Shelly BLU H&T (one month old) which was working fine. It was connected to my Shelly Pro 3 EM in bluetooth (approx 10 m away). Sometimes no connections were reported.
    I decided to change the gateway from the PRO 3 EM to an other device (in total I have 10 devices gen 3).
    So I deleted the Shelly BLU HT device (why ? I do not know but I did it). Since then, impossible to reconnect my Shelly BLU HT even to the previous other gateway, even few cm away.
    Any ideas ? Do I have to have the set someting special the the other device pairing with the BLU HT ?
    Thank for your support
  • For HT: If you click on the pencil symbol in the top right-hand corner, you can select Shellys as BT gateways in the 2nd step - it is best to simply use all the displayed ones.
    Mehrere PRO 3EM im Einsatz
  • Hi Thank for your reply.
    That's what I did and still the same. Some devices do not show up in the list of available Gateways, I do not know why.
  • Every device that functions as a possible gateway has "BLE Observer" at the top right of the title. All Pro and Gen3/4 devices can do this. Depending on the firmware version, this must be activated under BT - from 1.5.0 it is automatically active on these devices.
