Between Sunset and sunrise - how to make this work
Hinweis für Entwickler
  • Hello Everyone,
    I’m new to this forum and hoping to get some guidance on how to restrict my Shelly controlled lights to operate only during the hours of darkness, specifically between sunset and sunrise. It seems like it should be straightforward, but I’ve been struggling with it for several weeks without success. I can get them to switch on at Sunset and off again at Sunrise but that not wehat I'm after. We have Shelly controlled gates which when they open call for various lights to switch on so we can see, when its dark, how to get to the house. Clearly in day light this is not required.
    I have a range of Shelly products, from the Shelly 1 to the newer Pro series. I’m open to solutions, whether through scripting or using schedules. Any advice or insights would be greatly appreciated.
    Thank you!
  • There was a similar thread with a motion sensor to only work at night:
    Flutschi
    24. April 2025 um 22:09
    MIHO wrote a guide how to implement a virtual component switched on/off by sunrise/sunset which can be used as gate for other components
    https://shelly-forum.com/lexikon/entry/467-dummy-helfer-shelly-erstellen-mit-virtuellem-gerät/
