Shelly Plus1 Manual Override Switch Cancelled by Timer Action of Webhook
  • Hi All,
    I have a Shelly Plus1 which controls my front porch lights. I have my Ubiquiti cameras configured so that when they detect motion, they send the following command over webhook and turn on the porch lights.
    http://000.000.0.000/relay/0?turn=on&timer=20
    I also have a switch connected to the SW terminal, which I like to use as a manual override for when we are sitting on the porch.
    My issue is that when the cameras detect motion and send the webhook, the shelly starts the 20 second timer regardless of if the manual override switch is on or not. So even if I turn the override switch on, 20 seconds after I sit down, the lights go off.
    Is there a way to rewrite the webhook so it only sends the request if the override switch is off? Does anyone have a better solution? I'd rather not have to get a home assistant or anything like that.
    Thanks
