Hallo alle zusammen,
Ich habe mich in den letzten Tagen zum obenstehenden Thema belesen.
Dank des folgenden Eintrages war schlussendlich die vollständige Integration als Garagentor mit Status in Homekit möglich. ![]()
Das ganze wurde mithilfe von Node-Red, Mosquitto als MQTT-Broker und dem Node-Red Plugin
node-red-contrib-homekit-preconfigured durchgeführt. Der Shelly wurde im wie im verlinkten Beitrag angeschlossen.
Hier noch der erstellte Flow:
[{"id":"a716b60b.24c5a","type":"tab","label":"Garage","disabled":false,"info":""},{"id":"a7d6e5d3.093688","type":"hk-garage-door","z":"a716b60b.24c5a","pincode":"918-93-191","username":"29:43:4B:92:38:AF","name":"Garage","port":"40232","interceptget":"No","originalId":"a7d6e5d3.093688","x":580,"y":300,"wires":[["670fdbc0.dee5f4"]]},{"id":"f8d84560.01283","type":"trigger","z":"a716b60b.24c5a","op1":"{\"TargetDoorState\": 0}","op2":"{\"CurrentDoorState\": false}","op1type":"json","op2type":"json","duration":"20","extend":false,"units":"s","reset":"","bytopic":"all","name":"Öffnen","x":370,"y":360,"wires":[["a7d6e5d3.093688"]]},{"id":"f0a1bc2c.640db8","type":"trigger","z":"a716b60b.24c5a","op1":"{\"CurrentDoorState\": true, \"TargetDoorState\": 1}","op2":"{\"CurrentDoorState\": true}","op1type":"json","op2type":"json","duration":"5","extend":false,"units":"s","reset":"","bytopic":"all","name":"Schließen","x":380,"y":280,"wires":[["a7d6e5d3.093688"]]},{"id":"aa3adf1d.eb4b","type":"http request","z":"a716b60b.24c5a","name":"Garage auf","method":"GET","ret":"txt","paytoqs":false,"url":"http://192.168.2.24/relay/0?turn=on","tls":"","persist":false,"proxy":"","authType":"","x":925.5,"y":195,"wires":[[]]},{"id":"cfa66f2c.9c2f98","type":"http request","z":"a716b60b.24c5a","name":"Garage zu","method":"GET","ret":"txt","paytoqs":false,"url":"http://192.168.2.24/relay/0?turn=on","tls":"","persist":false,"proxy":"","authType":"","x":925.5,"y":238,"wires":[[]]},{"id":"b66635b8.78f0b8","type":"inject","z":"a716b60b.24c5a","name":"ZU","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":148.5,"y":78,"wires":[["f0a1bc2c.640db8"]]},{"id":"84a28f7f.ac14d8","type":"inject","z":"a716b60b.24c5a","name":"OFFEN","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":148.5,"y":118,"wires":[["f8d84560.01283"]]},{"id":"e870b49f.34ac98","type":"switch","z":"a716b60b.24c5a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":250,"y":320,"wires":[["f0a1bc2c.640db8"],["f8d84560.01283"]]},{"id":"a2c2b774.a3588","type":"mqtt in","z":"a716b60b.24c5a","name":"Sensor","topic":"shellies/shelly1-8CAAB505EA50/input/0","qos":"0","datatype":"auto","broker":"781d8278.6b2b84","x":130,"y":320,"wires":[["e870b49f.34ac98"]]},{"id":"670fdbc0.dee5f4","type":"switch","z":"a716b60b.24c5a","name":"","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":750,"y":220,"wires":[["aa3adf1d.eb4b"],["cfa66f2c.9c2f98"]]},{"id":"5edc4a62.51f934","type":"comment","z":"a716b60b.24c5a","name":"Status (CurrentDoorState)","info":"","x":130,"y":40,"wires":[]},{"id":"da249841.aaf68","type":"comment","z":"a716b60b.24c5a","name":"TargetDoorState","info":"","x":340,"y":40,"wires":[]},{"id":"cb25ee43.95b3","type":"inject","z":"a716b60b.24c5a","name":"Schließen","topic":"","payload":"{\"TargetDoorState\": 1}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":360,"y":80,"wires":[["cfa66f2c.9c2f98","a7d6e5d3.093688"]]},{"id":"509b11bc.427eb","type":"inject","z":"a716b60b.24c5a","name":"Öffnen","topic":"","payload":"{\"TargetDoorState\": 0}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":120,"wires":[["aa3adf1d.eb4b","a7d6e5d3.093688"]]},{"id":"781d8278.6b2b84","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Was im nachhinein geändert werden muss sind zum einen das MQTT-Topic, sowie die IP-Adresse des MQTT-Brokers und die IP-Adresse des Shellys. Die Aufsplittung passiert, damit die Nutzung auch mit anderen Smartswitches möglich wäre.
Die Einstellungen am Shelly 1:
- Timer Auto OFF auf 1 Sekunde
- Button Type auf Detached Switch
- MQTT unter den Developer Settings aktivieren
- Static IP ist dringend notwendig
Ich hoffe es hilft ein paar von euch!![]()
