ØS1 lights issue
  • I have a set of Shelly Pro Dimmer 2 PM uninstalled in my kitchen and want to connect a pair of Shade Ligths ØS1 pendants to the outputs.
    Problem is that the ØS1 has a built in power circuit which I understand converts the power to 24V DC and the lamp also has a built in dimmer function.
    I read that the Toggle/Edge functions might be able to bypass the dimmer function, but these options are not available in the Shelly menu (greyed out).
    Are there any fix to get the lamps working? I assume bypassing the built in converter in the lamp will not do any wonder?
