Shelly dimmer not responding
  • Hi
    I have just bought a Shelly Dimmer, it worked fine from beginning, I started configure it with MQTT and so on.
    When saving the configuration the device reboots, and then doesn't come up again.
    Led is flashing really slow, like on 5sec, off 0,5sec, on 5sec and so on. Have tried resetting it by pressing the button, but noting happens.
    is the hardware broken or can I solve the with some kind of software?
  • No, I don´t see it as an AP.
    And it doesn't react at all when I push the reset button.
    is it possible to flash the firmware on it again? or are there any orher debugging avaiible on the UART pins?
    Or will I void the warranty if I try to fix it myself?
    BR
    Per
