Hallo, ich habe heute mein Shelly Wall Display installiert und dann auf Homeassistant gewechselt. Dann habe ich nur einen weißen Bildschirm. Ich hatte in einem Video gesehen das ich da in Feldern meine Daten eingeben muss. Die kommen aber nicht. Ich habe unten nur die Leiste und ansonsten ist allen Hell. Hat da jemand einen Lösungstipp? Danke Oliver
Anmelden an Home Assistant
Genom33 -
15. Februar 2025 um 15:35 -
Unerledigt
Sorry kann zu. Restarts und andere Versuche hatten nicht geholfen. Einmal das Display entfernt und erneut aufgesteckt war die Lösung.
I have exactly the same problem. Occurred after update to fw 2.3.4. (20250212-115015/2.3.4-a71e59c7) White screen on Home Assistant. De HA integration still works, the device is still visible and I can operate the built in switch. But the HA dashboard fails to load. Tried reboot, factory reset but no luck.
Here some log info:
[2025-02-24 20:33:13.824][HomeAssistant] HA discovery started
[2025-02-24 20:33:14.031][Generic] Found HA service: Thuis at null:0
[2025-02-24 20:33:14.061][HomeAssistant] HA discovered: http://192.168.188.32:8123
{location_name=[B@cecf09f, base_url=[B@c2d15ec, external_url=null, internal_url=[B@c686db5, uuid=[B@8e20c4a, version=[B@339f7bb, requires_api_password=[B@ecba4d8}
[2025-02-24 20:33:18.826][HomeAssistant] HA discovery stopped
[2025-02-24 20:33:20.980][HomeAssistant] ?? item is checked, it's instance is {"name":"Thuis","scheme":"http","address":"192.168.188.32","port":8123,"path":"\/","query":""}, the instance is configured, but I will not process it. (Insert Ryan Raynolds' 'But why' meme here)(the last line is also part of the log
Please help, thank you!
I managed to solve the problem. I enabled ADB and connect to the Wall Display. I did not change anything as far as I know. But logging into the Wall Display and running the deamon probably solved the problem. The other possibility is changes to my wifi network; I upgraded one of my AP's so probably the Wall Display and/or Home Assistant changed subnet.
I don't know if the problem of this thread is resolved now. Genom33 should react on that.
TaffyV can you explain in a bit more detail, what and how you have done to make the adb stuff ? i already have enabled developer mode and also the adb function... I also recognized that when i try ping the walldisplay the times are very high up to 600ms....
Dieses Thema enthält 3 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
