MQTT steuerung
  • Servus
    Ich möchte den Dimmer über NodeRed steuern.
    Das übergebe ich an MQTT out.
    Aber der Dimmer macht nichts!! Er schaltet weder ein noch aus geschweigedem geht der Dimmer!!
    Was mach ich falsch??
    Dankte
    Gruß Jürgen
  • Moin, leider wenig Zeit, importiere dieses und nimm es als Beispiel:
    [{"id":"876b82d3c3cd447f","type":"template","z":"63a26414e7cd7d3d","name":"off 25%","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n\"turn\":\"off\",\n\"brightness\":\"25\"\n}","output":"str","x":820,"y":1100,"wires":[["b95b03c7ae720a38","6ae2e8955fa1d2ac","80c15785720e594a"]]}]
  • Jumare
    Hier ein Beispiel für den Dimmer 0/1-10V PM Gen3:
    Hier das Beispiel via "Import" in Node Red übernehmen:
    [{"id":"c42a8af9409498b7","type":"tab","label":"Flow Shelly Dimmer","disabled":false,"info":"","env":[]},{"id":"183411093f3bb7a3","type":"debug","z":"c42a8af9409498b7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":830,"y":460,"wires":[]},{"id":"117691efac3a96f6","type":"function","z":"c42a8af9409498b7","name":"0 on","func":"msg.payload = {\n    method: \"Light.Set\",\n    parameters : {\n        id : 0,\n        on : true,\n        // toggle_after : 2 // optional flip back time in seconds\n    }\n};\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":290,"y":320,"wires":[["bc09ef8e8aa696c4"]]},{"id":"920068ab161bed76","type":"function","z":"c42a8af9409498b7","name":"0 off","func":"msg.payload = {\n    method: \"Light.Set\",\n    parameters : {\n        id : 0,\n        on : false,\n        // toggle_after : 2 // optional flip back time in seconds\n    }\n};\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":290,"y":380,"wires":[["bc09ef8e8aa696c4"]]},{"id":"b6f7153f58c33130","type":"inject","z":"c42a8af9409498b7","name":"Turn On","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":320,"wires":[["117691efac3a96f6"]]},{"id":"0d2efc766de03a78","type":"inject","z":"c42a8af9409498b7","name":"Turn Off","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":380,"wires":[["920068ab161bed76"]]},{"id":"360fdec193ce2be4","type":"function","z":"c42a8af9409498b7","name":"0 toggle","func":"msg.payload = {\n    method: \"Light.Toggle\",\n    parameters : {\n        id : 0,\n    }\n};\nreturn msg;\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":460,"wires":[["bc09ef8e8aa696c4"]]},{"id":"876a7244736b7250","type":"inject","z":"c42a8af9409498b7","name":"Toggle","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":460,"wires":[["360fdec193ce2be4"]]},{"id":"bc09ef8e8aa696c4","type":"shelly-gen2","z":"c42a8af9409498b7","hostname":"192.168.178.195","description":"Dimmer","mode":"polling","verbose":false,"server":"df2c38cee1805993","outputmode":"event","uploadretryinterval":"5000","pollinginterval":"1000","pollstatus":false,"getstatusoncommand":false,"devicetype":"S3DM-0010WW","devicetypemustmatchexactly":false,"captureblutooth":false,"outputs":1,"x":540,"y":460,"wires":[["183411093f3bb7a3"]]},{"id":"c869a9b53e64042c","type":"function","z":"c42a8af9409498b7","name":"Set 70%","func":"// see also https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Light/#lightset\nmsg.payload = {\n    method: \"Light.Set\",\n    parameters : {\n        id : 0,\n        on : true,\n        brightness : 70,\n        transition_duration : 1 // 1 seconds\n    }\n};\nreturn msg;\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":600,"wires":[["bc09ef8e8aa696c4"]]},{"id":"a33c17aa459e71b9","type":"inject","z":"c42a8af9409498b7","name":"Toggle","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":600,"wires":[["c869a9b53e64042c"]]},{"id":"93552ba2cfc736b9","type":"function","z":"c42a8af9409498b7","name":"Set 0%","func":"// see also https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Light/#lightset\nmsg.payload = {\n    method: \"Light.Set\",\n    parameters : {\n        id : 0,\n        on : true,\n        brightness : 0,\n        transition_duration : 1 // 1 seconds\n    }\n};\nreturn msg;\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":540,"wires":[["bc09ef8e8aa696c4"]]},{"id":"8a85171b91f130ca","type":"inject","z":"c42a8af9409498b7","name":"Toggle","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":540,"wires":[["93552ba2cfc736b9"]]},{"id":"df2c38cee1805993","type":"shelly-gen2-server","port":"10001","hostname":"unimatrix"}]
