Reading two temperature sensors from shelly addon
Hinweis für Entwickler
  • I want to read the temperature of sensor ID100 and sensorID101.
    tried to use the following script but I'm getting Syntax error
    // Configuration
    let tempSensor1ID = 100;
    let tempSensor2ID = 101;
    let logInterval = 5000; // Logging interval in milliseconds (5 seconds)
    // Function to get the temperature value of a sensor
    function getTemperature(sensorID) {
    let status = Shelly.getDeviceStatus({
    component: "temperature",
    return status.value;
    // Function to log temperatures
    function logTemperatures() {
    // Read temperatures
    let temp1 = getTemperature(tempSensor1ID);
    let temp2 = getTemperature(tempSensor2ID);
    // Log the temperatures to the console
    print(`Sensor 1 Temperature: ${temp1}°C`);
    print(`Sensor 2 Temperature: ${temp2}°C`);
    // Set up a timer to log temperatures periodically
    Timer.set(logInterval, true, logTemperatures);
    what am I doing wrong ?
    2 Mal editiert, zuletzt von ilansch (29. November 2024 um 23:03)
  • The script runs on the Shelly with the IP 192.168.178.150 and accesses the Shelly with the IP 192.168.178.155 to which the temperature sensor is connected via the AddOn.
    If you want to query the script on the Shelly with AddOn and temperature sensor you have to change the line:
    { url: "http://192.168.178.155/rpc/Temperature.GetStatus?id=" + id },
    to line.
    { url: "http://127.0.0.1/rpc/Temperature.GetStatus?id=" + id },
    Einmal editiert, zuletzt von Viedotraum (30. November 2024 um 19:16)
