Shelly Duos turn off light switch
  • Hello all,
    I have a problem with my Duos.
    I can put up to 3 bulbs in my lamp. The electric circuit is built for a 2-button light switch, but I have bypassed 1 of the wires, so I just use a 1-button light switch instead to command all 3 bulbs.
    When I turn off 1 or 2 Shelly Duo (out of 3) everything works ok.
    When I turn off all 3 Shelly Duos, after 1 second or so, the light switch itself shuts down for some reason ... and I have to manually turn it on, because my Duos go offline.
    How do I solve this problem?
    Thanks
  • Nice to e-meet you :) Happy to join the community
    Correct, but I’m not doing this manually.
    I turn off the Duo from the App and after 1sec the nonsmart-switch (VL-C701 Livolo switch) turns itself off => Duos go offline.
    How do I turn off my Duos keeping the switch On?
    I’ve done some testing. Livolo switch will not auto-turnoff if there is at least 1 more bulb in parallel (either on or off - doesn’t matter)
    I think it has something to do with the overall circuit electric resistance
