REST API for dimming Shelly Pro Dimmer
  • I have three Shelly Plus I4 that I am using to control three Shelly Pro Dimmer 2PM.
    I was inspired by this script emulate_multiple_dimmers.js to let button switches control dimmers and got it working for turning on/off and setting brightness:
    curl "http://x.x.x.x/light/0?turn=on&brightness=100"
    However the dimming command from the script has no effect (script is written for Shelly Dimmer 2, and the command is mentioned in that API)
    curl "http://x.x.x.x/light/0?turn=on&dim=up&step=5"
    I cannot find any similar API command for the Pro Dimmer, does anyone know if there is a similar call? Its not documented here or here how to control dim up/down.
  • DHall 24. Juni 2024 um 22:56
    Hat den Titel des Themas von „REST API for dimming“ zu „REST API for dimming Shelly Pro Dimmer“ geändert.
