How to 'AND' function on Shelly Pro 3
  • Hi all,
    Pretty new on the Shelly devices and even more on scripting.. (i'm a newbie)
    Device 'x' = Shelly Pro 1
    Device 'y' = Shelly Pro 3
    I have this device 'x' of which i'm switching ON the relay '0'
    But... can you tell me on device 'y' how to 'AND' all 3 incoming switches and reset relay '0' from device 'x'?
    Like:
    If Sw1 AND Sw2 AND Sw3 (device 'y') are OFF then switch off Relay '0' from device 'x'
    Thank you for your help in advance
    Michiel
  • This may be implemented by an event handler in a script at device y. This handler receives any change of an input, store the status (off vs. on) in a variable and checks the three values like this:
    if(in1===off && in2===off && in3===off) Shelly.call("HTTP.Get", {url:"http://<IP address of device x>/rpc/Switch.Set?id=0&on=false"});
    respectively
    if(!in1 && !in2 && !in3) Shellly.call("HTTP.Get", {url:"http://<IP address of device x>/rpc/Switch.Set?id=0&on=false"});
    In the second variant the values of in1, in2, in3 must be of type boolean.
    Einmal editiert, zuletzt von eiche (3. April 2024 um 08:18)
  • Sorry, there was a mistake in my variant 2 above which now I have corrected.
    Unfortunately I don't have any Shelly Pro 3, but Shelly pro 2 and of corse Shelly Plus 1 ... So I can't test such a script. But it will works.
    My first variant above just shows the principle.
    But the incoming event has an input state which is a boolean value (true or false). Therefore my variant 2 works if you store the state of input:0 to variable in1, of input:1 to variable in2, of input:2 to variable in3.
    Ok, I understood, you need a complete script. Maybe I'll program a little script for you today or tomorrow ...
  • i've spent the whole day figuring this out, GPT is not helping either.
    Another solution to me would be similair like:
    If input-1 OR input-2 OR input-3 is ON then Output-x is ON
