shelly 2.5 reflash firmware
  • This is the only thread I can use to post as other are in german language.
    I have one shelly 2.5 that suddenly stopped working. No connection, no status light.
    I assume it is an hardware problem and pwuld like trying to fix it. Du you have any advice?
    A firmware reflash would help?
    Wher can I get the firmware?
    Thnak you
    Hi,
    you can try first a hard-reset.
    firmware is available in the filebase.
    Please have a look into your setup and activate "English Content" in "Multilingualism". ;)
  • Thank You, I have english activated.
    Hard reset what do you mean?
    I completely disconnected the device but no changes. Light stays off.
    I suppose it is a HW problem, I opened the device but at first glance everything seem ok, Capacitors charges and power form socket is there.
  • Hi, no luck. Tried the procedure. Nothing, no relay action..no light. I think it is gone. I had it replaced under warranty but before gettin into garbage I would like try fixing it.
    I will try reflashing, but I believe some electronic component is gone
