How do I make a Shelly 1PM mini gen 3 turn off after 5 minutes if its output is consuming zero watts?
Hinweis für Entwickler
  • I am ultra new to Shelly stuff. Two days using them.
    I have a device connected to an outlet using a Shelly 1PM mini gen 3 over 220V Europe.
    I am using it through homebridge/homekit but I wonder if there is a way to create a script inside the device that can turn it off, if the output is consuming zero watts for 5 minutes.
    I mean, I turn the device off. The device keeps off for 5 minutes. Shelly 1PM mini gen 3 turns off.
    Any way to do that using scripts?
    Thanks
    Einmal editiert, zuletzt von LimaMike (17. März 2024 um 22:12)
  • Yes, of course.
    Question: Does it have to be exactly 5 minutes or can it be up to about 6 minutes?
    An event handler receives the values and when power is 0 for the first time, it saves the timestamp.
    If power > 0, the timestamp is deleted.
    If 5 minutes later (current timestamp - saved timestamp) the power is still 0, the output is turned off.
    This is the simple algorithm.
