Send parameter to script via HTTP
Hinweis für Entwickler
  • hello everybody,
    I would like to send a parameter to a script via http from a browser.
    For example, I would change "SogliaTemp" with another value.
    Is it possible? how can do it?
    thank you
  • You can also try this script:
    It’s important to know where you save your script. If you save your script in the 1st slot, then your URL will be:
    http://<IP of your Shelly>/script/1/myTrigger?SogliaTemp=60.5
