Shelly to replace a digital programmable clock for pool filtration pump
  • Hi,
    i have a filtration pump for my pool managed by a digital programmable clock and i would like to replace the digital clock by a Shelly 1.
    There are currently 3 components :
    - the digital clock itself to be replaced by the shelly 1 (1st pic on left)
    - the relay activating the filtration pump and activated by the digital clock (1st pic on right)
    - a switch with 3 positions : left = permanent ON, center = OFF, right = clock managed ON
    I hope the shelly 1 can replace "only" the clock by connecting the current wires to the shelly connectors.
    What i am not sure is how to connect these wires.
    What i can see as wires on the digital clock :
    - left : 1 & 2 with M symbol between should phase and neutral
    - right : 3 orange wire goes to switch position permanent ON, 4 : 1 black wire goes to switch position clock managed ON, switch position OFF has a blue wire
    If this description is enough for you to help me finding how to wire the shelly 1 there i would be pleased to get ur advices.
    If you need more details i can provide.
    The goals is to :
    - be able to program the planning of ON/OFF for the pump directly from my Shelly App on my phone
    - still be able to use the switch for permanent ON, permanent OFF or scheduled ON/OFF as currently.
    So, at the end just replace the current digital clock.
    Thanks in advance.
  • i found the current connection schema here below
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. and i just want to replace the clock which is in the center
    Hi bemo47 , welcome to the forum. :)
    I'm sorry that you didn't get any help from the forum.;(
    But I am all more pleased that you have found a solution yourself.:thumbup:
    Perfect.8)
    Have fun here.
  • good night bemo47
    i also want to do the same and my watch is the same as yours.
    Did you let the watch stay the same and turn on the shelly or remove the watch?
    Do you have photos of the final result?
    thanks
