Shelly EM MQTT disables Cloud and mobile app access
  • When I enabled MQTT in my Shelly EM, I got the cloud option disabled and as a result, the EM was not accessible through the mobile application.
    I am aware of the warning:
    Enable MQTT
    WARNING: If you enable MQTT - actions via Cloud connection will be disabled!
    but is is specific about actions, not the whole Cloud connection.
    Also, when I logged through web in my device and enabled back the Cloud option, MQTT was disabled.
    Is this the expected behavior? I am running the latest firmware
  • but is is specific about actions, not the whole Cloud connection.
    Afaik it affects the whole cloud connection but not the actions (=webhooks).
    Yes, that is the documented behavior. You can only use either the cloud or MQTT in Shelly Generation 1.
